Gaming System $2,000-$2,500 Help1
SaViOr-
Hey guys im going to be building a new gaming pc in a little bit, i want to know what i should get. I want to get Athlon 64 cpu, not much into intels. I need you guys to help me pick out some stuff, i wont be needing a Case,monitor or PSU as i know what i'm going to get for those, but i need help on all the other stuff. Please post your suggestions here.
Thanks in advance
SaViOr
Athlon 64 3700+
ASUS K8V-SE Deluxe motherboard
Plextor 16x DVD-Burner, dual dvd if you want
74gb raptor, additional 160gb SATA drive
Sound blaster audigy 2zs or Envy Based M-Audio sound card
Radeon x800XT Platinum -> if you can find it
1024mb Mushkin Black pc3200 RAM
why the 3700+? if he's going that high the 939 makes sense and adds the future-proofing.
I could possibly go up to $3000 or $3500 or maybe little more if that opens up any better/faster options. :D
3700+ performs better then the 3800+, and it's on a more proven platform. by the time you need to upgrade from that, DDR2 will be desireable and pci-e graphics will be in full swing. this saves money that could be used in far better ways.
mobo asus
http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-510&depa=1
129
73GB 10,000rpm 4.5ms seek
http://www.newegg.com/app/viewProductDesc.asp?description=22-144-160&depa=1
two of these raid 0 175 rebate 25$ so 150 ... 300 for both
512x2 cl2 xtra low latency
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-522&depa=1
2 if you want 2GB 540 for 2GB
fx-53 1mb l2 cache dual channel support, and long time future proc socket
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-459&depa=1
835
6800 ultra
bestbuy.com
499
2303
200$ for case and PSU
thats 2503, no tax no shipping included ;p
im not huge on sound, so i think mobo sound is fine
DVD-rw 80$
dvd - 30$
oops 2610
