Pyrophoric
- Sep 28, 2010
I am currently using a DGL-4500 and have been having a lot of problems regardless of firmware.
Everytime I want to host a CoD 4 dedicated server I have to restart the router and occasionally put the server rig in DMZ. I can take it right out of DMZ and everything still works.
I also cannot host an Unreal Tournament 3 server but if what I have googled is correct, I need a router with full cone nat.
Most of the stuff in my home is connected via ethernet, not wireless. The only devices we use wirelessly are our iPhone 4's, Wii, a computer in the back bedroom and guest computers (when friends come over).
What I really need more than anything is a reliable and good router primarily for wired. That said, not much emphasis is put into reviewing wired routing features anymore.
Any opinions on a good router to go with? I was thinking about the WNDR3700 and an additional D-Link 8 port switch. My two main computers hooked directly to the router and then everything else connected to the switch.
I know it may not be the smartest thing to do but maybe just hook the main rigs to the switch and anytime I want to host a server just go straight from the switch. Oh maybe, keep the switch primary and forget buying another router altogether. Just use the current DGL-4500 for broadcasting wireless go and the switch for everything else.
If a hacker wants to get in, they will get in regardless. So a decent firewall (Norton) + a switch should be ok or not?
Thanks for any help that can be provided!
