Gaming Rig (starcraft)
Corban227
This rig is for a bud of mine. He will be starting with only starcraft and then possibly branching out to other games. No photoshop or video processing. 75% Gaming and 25% web browsing
I am shooting to keep it between 500-700. I would prefer to stay on the cheaper side. I am giving him an old 19in monitor, but I would prefer to give him a new one if it can fit in the budget.
I live in Southern california, OC specifically. I am about 30 minutes away from a microcenter and a frys if parts would be cheaper than online.
I am building from scratch. Case, Power supply, HDD/SDD (Depending on price), Ram, Video Card, Sound Card, DVD Drive, Monitor (this part is optional. It would be great if someone has a better build with no monitor and a lesser build with a monitor)
No parts being re used
6) Will you be overclocking?
no
Right now it is a 19in, not sure the resolution. If I were to get a monitor, would probably lean towards a 22-24in
1 week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
None of the above
No unfortunately...
I am building the rig as a gift but he knows about it, so I will be able to ask questions if you guys have specific questions to ask. Mostly he will be using it for SC and then branching out from there. Possibly going the battlefield route in the future but not for a while probably. This computer will most likely be built and not changed or added to till it needs to be. My friend does not like to tinker.
Thanks
Let's start with the cheap route for now. Here's the tower:
$120 - Intel Core i3 3225 (MC in-store special)
$30 - MSI B75MA-P45 (instant $40 discount when purchased with processor)
$40 - Patriot PSD38G13332H 4GB DDR3 1333 DIMM
$60 - Toshiba DT01ACA100 1TB HDD
$16 - LG GH24NS95 SATA DVD burner
$55 - Corsair CX500 500W PSU
$60 - Corsair 200R ATX mid-tower case
$381 - Subtotal (not including sales tax or rebates)
Grab the case and RAM from Fry's but go to Micro Center for everything else.
For the OS, you can choose between Windows 7 Home Premium or Windows 8, either of which will cost you around $100. Make sure that you get the 64-bit OEM/System Builder disc.
For a 19 inch monitor, you don't really need much in terms of a video card. A cheap card like the GTX 650 or the HD 7770 should be more than enough, regardless of the resolution.
You can buy a larger monitor with a 1920x1080 resolution for under $200, but you may have to spend at least the same amount (most likely more) for a video card good enough for medium settings at that resolution. For StarCraft II, a GTX 660 (non-Ti) or an HD 7850 would be enough (both cards start at around $200 each), but for most first-person shooters, you should "start" by looking at the GTX 660 Ti or the HD 7870 (though you'll probably spend upwards of $300 on each card).
^ In addition to what tiraides mentioned, I'd prefer nvidia cards for purely starcraft 2.
SC2 is heavily intel/nvidia biased.
if you plan on playing more demanding games than SC 2 i would suggest getting a 7870 gpu
Damn; the i3-3225 appears to be out of stock at your local MC.
You could go with the i3-3220 instead, or you could go with the quad-core i5-3470, which offers a bit of a performance boost. Regardless, the MSI board is now $70 instead of $30, which does limit a few options.
I know your friend doesn't like to tinker with completed builds, but is he considering upgrading the monitor any time within the next six months?
