Hi all, so here is the deal, I am building a new system for gaming...here is what I have waiting in my cart...the rest , widescreen (22 & 24 dells ) mouse etc I have. I couldnt decide all week ( haha, ive been reading/researching a ton ) on this or basically the same thing only with a i7 920/Ram/Mobo. I decided to spend less and go with this...maybe a better card or case instead.
I would like your expert opinions on my choices , also if I should go ahead and go with the i7 920 instead. ( as you can tell if I have 2 things to choose from I will take a month to do it >< it drives me nuts...lol)
Also...and most importantly, i need opinions on :
The CASE , I cant decide on the Antec, or the Coolermaster HAF 922, or the Lian li Lancool PC K62. ( seriously, i cant decide...im crazy that way...haha)
And the GPU: Will this one do til after the dx11 cards come out and prices have gone down a bit...or should i go with one now..if so which one? I dont want to spend much more on a card..maybe 75-100 more than the one I have chosen at 200.00.
I chose ATI, even though I have always been a nvidia guy...but it just seems the price difference just isnt worth it.
I will also be installing Win 7 , this is my first build in 3 years and probably wont be able to do another for at least 3 years...so I have that to consider also...
And thank you for any responses...
CPU
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
MOBO
GIGABYTE GA-P55A-UD4P LGA 1156 Intel P55 ATX Intel Motherboard w/ USB 3.0 & SATA 6 Gb/s - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128409
RAM
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMD4GX3M2A1600C8 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145265
PSU
Antec TruePower New TP-750 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025
HDD
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
HSF
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
CASE
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
GPU
XFX HD-489X-ZSFC Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150438
DVD Burner
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
CPU
MOBO
RAM
PSU
HDD
HSF
CASE
GPU
DVD Burner
