Gaming Rig, need input, thanks
jeeden
I decided it was time to upgrade because my videocard(I think) has crapped out. It's odd, once my computer is on I can see things fine, but if I turn it off and turn it back on quickly, the screen either stays black(looking for a video card I guess) or displays random chaotic colors in squares and such. Same happens if I try to restart. So I just shut it down by killing the power in the back or holding the power on button if such happens. But if I wait like 1 or 2 min, or get lucky, it turns on fine, especially if I want say til the morning(guess it's cooling down or releasing charge??). It is a pny nvidia 6800 128mb vid card, asus k8v deluxe mobo, amd 3200+ cpu, 1gb xms cosair memory.
Any ideas on the problem would be nice, although bottom line, it doesnt work.
I want a new rig because of this failure and because of warhammer online set to release 2008 Q1. I;ve already an:
CPU:
AMD Athlon 64 X2 5600+ Windsor 2.8GHz 2 x 1MB L2 Cache Socket AM2
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103771
Model: ADA5600CZBOX
(got it cheap for $120, I know I know intel is killing AMD atm)
PSU:
X-Finity 500 Watt PSU - Titanium
http://www.ultraproducts.com/product_details.php?cPath=52&pPath=383&productID=384
Heres what i'm thinking of buying:
RAM:
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
Model: TWIN2X2048-6400 (5.5.5.12)
Motherboard:
ASUS M2N-SLI Deluxe Socket AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
Model: M2N-SLI Deluxe
Video Card:
XFX PVT84GUDF3 GeForce 8600GTS 256MB 128-bit GDDR3 PCI Express x16 HDCP
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150228
I am kind of on a budget as I dont want to spend more than 400-500.
If need be I wouldnt mind upgrading the video again in say 6 months for another 150.
I will most likely also upgrade my memory by ordering another pair.
Reason I picked the CPU also is that from what I read, correct me if i'm wrong, that with its cpu clock, it can run the ddr2 memory at its full 800mhz while the 5800, 6000, etc does not because of the way it divides. Plus I want this machine to run cool since I typically leave it running overnight.I picked the video card because it is dx10 compatable and the motherboard because it looked solid, has nvidia chipset, and has a heat sink on it.
Any thoughts? I appreciate it
You could proberbly find some cheaper RAM and I would swap the PSU for the X-Clio Goodpower 500w. Also think about changing the GPU down to a DX9 one or up to a 8800gts 320mb.
What resoloution are you currently using?
Running 1280x1024 I believe, on my laptop right now, not my desktop.
Resolution may change if I decided to upgrade to a 19/20" LCD.
Why would I want to go DX9?
Why swap PSU?
Aren't 8800gts 320mb cards $300? I want to spend $200 max on a card. unless its completely worth it.
8800 is much faster than any 8600 series card. If you got the cash buy it...:)
Why swap PSU?
Thats nice, but your desktop won't run on your laptop screen, so what resolution is the monitor you have for the desktop?
You could go DX9 for now because its cheap, and upgrade to an 8700GTS when they're released in a few months.
XClio Goodpower 500W is cheaper while still being a good quality budget PSU.
You can find an 8800GTS for around $250AR. It should last you a while, but I'd go for a DX9 holdover card for now, and upgrade to the 8700GTS in Nov. for $250.
I'm running 1280x1024, I meant I was responding on my laptop.
So I should go dx9 for now and upgrade into 8700s in say january 2008?
I'm fine with that if it'll save me money.
What cards do you suggest then for $100-200?
The PSU has already been bought, got it for free.
I mainly want something to hold me over for now and be able to play warhammer online.
If you are playing at 1280x1024 then the X1950 Pro is probably the best choice. DX10 is virtually identical to DX9 right now, so I don't see much point in going for a DX10 card. I would also go the Intel route, try to get something like an E4400 and overclock that. It would turn out much faster than the AMD that you are currently looking at. The PSU could go down to a good 400W PSU if you wanted but I would stick with the X-Clio, it is a good power supply for a very good price. If you wanted to spend a bit more you could get the Corsair HX520 but there isn't really much point IMO. I would try to stretch for the 8800GTS though, but money is an issue, so the X1950 Pro will be fine.
Oh, is that what you meant... lol. 1280x1024 isn't demanding at all.
He can't go Intel cuz he already bought the AMD CPU.
The 8700GTS is out in November (rumor; price is rumored to be $250), the GTX/Ultra replacements are out in Q1'08.
The X1950GT can easily reach X1950Pro speeds with ATI Tool:
$115 - Sapphire 100199L Radeon X1950GT 256MB GDDR3 PCI Express x16 HDCP
