Hello! Just want to say thanks for all your help the past week, I'm looking at another build now and here are my thoughts...
-Building a Heavy Duty Gaming Rig
-I have $3,000 Canadian to spend, mind you, you don't have to spend it all
-I live in Southern Ontario.
-Everything is needed for this build, I have no parts to re-use.
-As of now, I do not plan on over-clocking.
-I will use two 22" LCD monitors, yet to be selected.
-I plan on building the middle of January, hope to get a build list complete in time for the Christmas sales.
-Crossfire and SLI are needed, I don't think RAID is necessary, but I wouldn't object to having it. The more bells and whistles the better, to an extent at least...
This is the current parts list I put together, feel free to point out my errors.(prices are Canadian)
Case-----COOLER MASTER RC-690-----------------------------------------------------------100.00
PSU------CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready--------152.25
MoBo----GIGABYTE GA-EX58-UD5 LGA 1366 Intel X58 ATX Intel-------------------349.99
CPU------Intel Core i7 920 Nehalem 2.66GHz------------------------------------------------369.99
HSF------Stock, might upgrade if I overclock later-------------------------------------------0.00
Ram------two(G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000)------136.12
Video----two(SAPPHIRE 100259-1GL Radeon HD 4870 1GB)-------------------------665.54
HD--------two(Western Digital Caviar Black WD5001AALS 500GB)------------------184.98
Optical--two(Pioneer 20X DVD±R DVD Burner IDE Model DVR-116DBK)--------75.98
Subtotal-------------------------------------------------------------------------------------------------2034.85
**I want cutting edge, not bleeding edge
Prices have been adjusted according to the quantity
Ok, I switched to dual cards. What cables do I need to make that work?
Well, in your opinion is this a high end gaming build? Any ideas on how to improve it would be appreciated. Also, if you see any issues of parts not fitting, or supporting each other, let me know. Thanks for your help guys, I would be lost and playing a 486 still without you.
