Gaming rig for a friend
eggzile
Gaming Battlefield 3, Diablo 3, Star Wars the old rebuplic
$1000 Tax and shipping included
United States, Tampa, Florida
CPU, GPU, PSU, RAM, Mobo, Case, Hard drive, DVD drive,
keyboard, mouse, monitor,
6) Will you be overclocking?
Maybe at some point
1920x1080 he wants to use this on a 30inch samsung tv
In the next couple of weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Hes not really sure, i included most but went with a cheaper board to get the price down
Yes, windows 7 64 bit
I picked this out based on what i would get
DVD - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 $18
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811112320 $120
HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284 $135
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549 $260
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 $90
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345 $54
MOBO - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131773 $133
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 $220
Total $130
I haven't showed this to him yet so he might want some changes but id like to know what you think of what I've put together.
Have you thought about adding a aftermarket HSF?
Yea, i haven't run it by him yet, it will raise the price a bit so he might not want to so if someone wants to recommend a good HSF i can run it by him.
$26.99 - COOLER MASTER Hyper 212 Plus
edit
After looking over your build, you can save money by going with these instead.
$44.99 - G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Also go with this faster HDD.
$109.99 - HITACHI Deskstar 7K1000.D HDS721010DLE630 (0F13180) 1TB 7200 RPM
Plus this faster GPU @ 1080P gaming, it's more competitive with a 6970 and only costs a little bit more.
$279.99 - EVGA 012-P3-1571-AR GeForce GTX 570 HD
$79.99 - Antec EarthWatts EA-650 GREEN 650W (Use promo code PAXANT15 for $20 off TONIGHT, even if you don't get anything else. Get this tonight.)
