Gaming re-install question
rehab
I am thinking of upgrading my mobo. I have installed many games on a secondary drive in my pc. My question is, if I upgrade my mobo, will those games on the other drive still play with windows reloaded on my primary? Is there any info regarding the installs loaded on my primary OS drive? thanks.
If you are simply installing the motherboard then I don't think you would have to re-install the the games on the other drive. The windows registry entries having changed nor any other installtion files that may have been saved to the C:\
You will need to install the new boards drivers but I think you will be ok.
well since it´s a new mobo i´d recommend to u to reinstall everything, that includes windoze and your gamez
