Gaming PC
ark1
Budget: $2000 CAN (about $1900 US) but I have no problem adding a bit more if it can make a significant difference.
Source: probably ncix.com as they are in Canada and seem to offer reasonable prices.
Need: a PC that will be mainly used for gaming and occasional movie.
The System (tower only)
CPU: Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB Retail $279.99
Motherboard: I do not really know what to chose. I want a motherboard that is SLI ready and can support SATA2 technology. I found this motherboard that seems getting good reviews ASUS M2N32-SLI Deluxe ATX AM2 Nforce 590 SLI 2PCI-E16 1PCI-E4 1PCI-E1 2PCI SATA2 1394 : $202.92 but I am willing to hear other alternatives.
RAM: In order to maximize performance based on my CPU, what ram should I get? At the moment I am looking for 2GB. I see Corsair XMS3 TWIN3X2048-1066C7 G 2GB DDR3 2X1GB DDR3-1066 CL 7-7-7-21 Dual Channel Memory Kit but the price is $484.99..has the ram gone up so much or am I looking at the wrong ram?
Video Card: EVGA E-GEFORCE 8800GTS 500MHZ 640MB 1.6GHZ GDDR3 Dual DVI-I HDTV Out HDCP DIRECTX10 $442.34 after mail-in rebate. My intention is to get a second card (SLI) in a while when the price drops.
HD: Looking for SATA2 HD here. Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ $93.83
PSU: What PSU should I look for if I want to run this system. Keep in mind I want to add another video card in a while.
Sound Card: Creative Labs Sound Blaster X-FI Xtreme Gamer 24BIT Sound Card 7.1 PCI Retail Box: $118.74
CD/DVD RW: LG Black 52X24X52 CDRW& 16X DVD Combo INT EIDE Atapi OEM: $36.51
Cooling: Will the basic cooling be enough or should I look for some extra stuff?
Case: the cheapest :)
Right now I am at $1565.59 but I have to add PSU + case + possibly extra cooling which I guess will get me to about 1700-1800 mark. I will also get a mouse + a new keyboard.
Any recommendations for the missing pieces or changes to what I have selected are welcome.
Thanks
i would consider getting a motherboard that supports the processor you picked. Cause you are going to have a hell of a time fitting that intel chip on a amd motherboard
Hah, thanks. Any recommendations on the mobo to pick?
Gigabyte DS3R
He needs SLI support. so its NF 6 only >_<
P5N32-SLI+ SE might be a good bet, its decently cheap, x32 SLi :)
Although if this isnt a prebuilt as is suspect it isnt, then you would be better off in general hardware.
if it IS a prebuilt, there are much nicer builders than NCIX. while I love them for parts, and have bought everything from them, for 50 bucks, I doubt they build a good computer...
Velocity Micro or Maingear should have a really nice configuration in your price range, and both ship here :)
Thanks, I guess Hardware section will be better. Can a mod delete this thread please?
get a 150gb raptor or that $200 750gb WD drive on newegg.... both will vastly outperform any 320gb 7200rpm drive.
What size monitor will you be gaming on?
If you don't have a 24" LCD (1920x1080 or higher), then you don't need SLI. SLI is only worth it if you can afford 2 GTX's to drive at least a 2MP screen. Otherwise, stick to a single card solution. SLI as an upgrade path isn't that great either, again, unless you have or plan on getting a large LCD.
If you go SLI, get the eVGA 680i SLI A1 board. If not, go with a P35 based board, like the GA-P35(C)-DS3R.
FYI, Q6600 prices will drop to $266USD after July 22nd... well, thats the rumor, anyway. Also, current batches of E6600's can't OC too well, so you might be better off with an E6420 (I'm assuming you'll be OC'ing). As for cooling, go with a Tuniq Tower, Thermalright Ultra 120 (extreme), or Scythe Ninja Plus Rev.B.
For a PSU, the Corsair 620W will be more than enough, even if you got two GTX's to run in SLI. If you don't need SLI, go with the Corsair 520W (which can also run two GTS' in SLI).
Yes, you're looking at the wrong RAM. DDR3 is brand new and shows no advantages over DDR2, currently. It still needs time to mature, give it about a year or so, maybe sooner. In any case, go for some DDR2-800 with timings of 5-5-5-15 or better. Don't pay a huge price premium for 4-4-4-12, since you won't really notice the performance difference in everday usage, anyhow. You'll only see the difference in benchmarks.
Drop the X-Fi if you're goin with Vista.
