Gaming PC for 800 bucks, thoughts please.
Ampsonic
Building my roomate a new PC, budget is about 800 shipped.
Here's what I came up with, tell me if you see any tweaks or obvious changes. Haven't built a gaming machine in a while.
MSI K8N Neo4 nForce 4 - $80.00
Amd Athlon 64 3200+ Venice - $160
XFX Gefroce 6600GT 256mb PCI Express x16 - $165
2x Kingstong HyperX 512MB DDR 400 - $117
Seagate Barracuda 7200.7 SATA150 NCQ - $85
Sound Blaster Audigy 2 Value -$45.50
NEC DVD Burner $39.75
Antec SLK2650-BQE Case w/ 350W Power Supply - $75.00
Total $767.25 + $51.46 shipping = $818.71
Change the hyper-x to the Corsair Value series and change the 6600GT to 6800GS. You'd see a much better gaming performance.
oh You might also want to go with a case without the PSU and get a seperate PSU with a little bit more juice.
I agree with switching to Value RAM and upgrading to a 6800GS. Otherwise, everything looks great.
Where are those prices from? My cousin's looking to do the exact same thing so maybe I'll go with what you picked out too.
Thanks
Hmm, I'll offer my suggestions, ignore em if you dont like em.
Case + PSU: An Antec case/psu combo, perferably one with a 400 Watt PSU or greater.
MOBO: DFI Nforce 4 Socket 754(Yes 754, I'll explain later)
CPU: 754 Sempron 2800+(More on this later to)
RAM: Gskill DDR500 1 Gig stick
Vid Card: 7800GT
HD: Sata Drive, Maxtor, Seagate 7200.8 or newer, WD.
Optical Drive: DVD burner
CPU Heatsink: $30 Zalman Flower
Why 754? Cause its cheaper. That 2800+ will overclock effortlessly to 2.2 Ghz and beyond, with stock volts. That will give you the same performance or better than a higher priced 939 setup. With the money saved you can get a 7800GT which is 2x better than a 6800GS or a lot better than a cheap 6600GT.
Of course you cant upgrade to dual core later on, but I really dont think a buget system will be upgraded much.
I think l1ght is right, if you're going to overclock, stick with 754. 939 is going out in a few months anyways. When you're playing games, the video card is going to mean more than the processor(For the most part).
Not sure I want to deal with overclocking, perhaps if the system were for me. He really wanted to keep upgrade options open down the line hence the 939.
Although, I'm running a 3000+ 754, is that easy enough to overclock?
Should be. Well, his upgrade options are only going to be open until march anyways. Its up to you though I guess.
Here is a kick ass rig i build a few weeks back for less then $800
AMD 3200 Venice
I sold him my mobo so it was a lil cheaper, but ABIT KN8 Ultra is good mobo
1GB Corsair Value RAM
eVGA 6800GS
Maxtor 200GB HDD
NEC 3550A DVD Burner
Antec Sonata II Case with PSU
That should come out to around $800 and it will kick ASS. :D :p
EDIT: For OCing, just run a divider, thats what i did with that rig.
