Gaming PC build
DMGZone
Hey everyone, I've just ordered the parts to build my gaming rig with, and thought I'd join a forum to see what other people have to say.
I'm trying to run things like Crysis, WoW, Cod4, Fall Out 3, Far Cry 2, etc..
So, here it is:
2 Masscool 120mm Sleeve Bearing Case Fans
4 gigs of Corsair TWINX 2048MB PC6400 DDR2 800MHz E.P.P. RAM
Windows Vista Home Prem 64-bit DSP OEM DVD
Seagate 500GB Serial ATA HD 7200/32MB/SATA-3G
Biostar TA780G M2+ AMD780G Socket AM2+ Motherboard
AMD Phenom X3 8450 2100Mhz 3.5MB Socket AM2+
Lite-On DVDRW 20X SATA OEM w/o Software
XFX GeForce 9800 GT 512MB PCIe w/Dual Link DVI
Ultra LSP750 750w Power Supply
Ultra eTorque Silver w/Clear Side Mid-Tower Case
So for a gaming rig, how would this be?
So you've already ordered these parts that would make a panda cry?
I'd say: Let see some pics and performance numbers!
(If you want input or feedback, it's best to ask for it before purchasing your parts. Though we'll still help you if you need it.)
Agreed. Not a lot of feedback can be offered after the purchase is made. About all that can be said is, middle of the road. Woulda, coulda, shoulda bought this part instead of that part. The system built will play almost anything out now just not maxed to the gills
you bought that already? all we can say is it'll work and pretty well but if you had come to us before you bought that, we would have saved you a lot of money and you would have gotten a better PC.
nothing can be done now.
+1 on tiraides pics and benchmarks please.
