Gaming PC Build (First Time Builder)
VerniusIx
I am looking to build new Gaming PC. I have never built a system before, have never even upgraded one. I have used laptops for gaming for years. I hate to use the term but I am a total noob. I have had friends or IT people take care of all my problems, I have never even installed windows.
I have a budget of $2500 USD. This amount must cover all parts including a monitor.
So far this is the build I have been looking at
Case http://www.newegg.com/Product/Product.aspx?item=N82E16811119225 $180
PSU http://www.newegg.com/Product/Product.aspx?item=N82E16817171049 $170
Mobo http://www.newegg.com/Product/Product.aspx?item=N82E16813157263 $255
CPU http://www.newegg.com/Product/Product.aspx?item=N82E16819115072 $225
Ram http://www.newegg.com/Product/Product.aspx?item=N82E16820233144 $90
GPU http://www.newegg.com/Product/Product.aspx?item=N82E16814121489 $490
Total: $1410
I have chosen the Motherboard and the PSU for the upgrade options they give me later on. I am not sure about this Motherboard, it seems that people are having a ton of problems with, but it seems to be the best socket 1155 Motherboard that has PCI express 3.0.
I would like to have a SSD for a boot drive and a 2TB HDD for primary storage.
Thanks to all those who reply in advance. You are helping turn a noob into, well, not a noob!
Pretty much what Lord Nassirbannipal said: Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can better critique that build.
With that said, there are a few issues with that build:
- That motherboard is ridiculously overpriced for something that only has a 1 to 2 year warranty. There are better bang for the buck motherboards out thre are equal or better than in quality as that AsRock while having a longer warranty.
- You can't use PCI-E 3.0 at all with socket LGA 1155 until you upgrade to the Ivy Bridge CPUs coming in late April. In addition. PCI-E 3.0 doesn't really matter at all for a single GPU config. PCI-E 3.0 really only matters when you're doing Crossfire
- That PSU isn't that good. If you're gonna go stupid overkill with a 1000W PSU, at least choose a good one like the Corsair 1050HX.
- That RAM is a poor choice if you're planning on using air-cooling heatsink fan since its tall heatsinks will interfere with such coolers.
In addition to the stick questions, please answer the following:
- Which games are you (planning on) playing? At what (preferable) level of visual quality?
- Are you going to use a flight stick, driving wheel, or gamepad as well?
- Outside of gaming, what is the most resource-intensive task that you would like to do?
- Would you prefer a "regular" tower PC, a desktop PC (like a Shuttle), or something else?
It will be used for gaming.
Budget is $2500 USD
USA
I need:
Case
PSU
Motherboard
CPU
GPU
Ram
Monitor
6) Will you be overclocking?
I might
7) 7) What is the max resolution of your monitor? What size is it? Minimum resolution will be 1920x1080. Size will depend on price of rest of build. I would assume between 20-24 inches
In the next 90 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
I need Crossfire support. SATA 6gb/s
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I will be using Windows 7 64bit
I will mainly be playing:
Age of Conan
WoT
Mechwarrior Online
SWTOR
Tribes Ascend
CS
I would also like to be running two monitors minimum, with a 3 monitor eyefinity setup eventualy.
I will also be using a HOTAS control setup for MWO.
The most intensive non-gaming related activities will be photoshop
I would prefer a Tower style case with lots of room for expansion. While I am only starting with one 7950, around midsummer I plan on adding a second.
[/COLOR]8) When do you plan on building/buying the PC?
In the next 90 days
IN that case, I recommend that you wait until late April to do this build as Intel is releasing new CPUs around that time frame. In addition, there will be a new line of motherboard coming out around that same time frame. That's well within your 90 day plan.
So please come back in about 60 days and ask for advice then. You'll get up-to-date build advice then.
