Gaming on @ 1440x900
legendz411
So, I don't have a super huge moniter and I'm fine with that. However, it seems that all the reviews for any card release after the 7XXX series are in resolutions that I never see.
Obviously, a card that runs crysis on low @ some high-def resolution will be able to crank more power at a resolution with a few million pixles less to display.
My question(s) is this. Why did reviewers stop testing at 19" moniter display resolution? It can't be that dead? It would also serve perpous to show what a card can do at a lost res. I guess I'm just finicky because there are no more reviews for 19" resolutions anymore, but it's a thought.
What's overkill on a 19" moniter then? I can't see someone buying anything over a 8800GTS for even the most demanding games.
That's precisely it. If a GPU can max out a game at 1680x1050, then why test it at 1280x1024?
I have sli 8800gts 512 @ 1440x900 and it's great. If I turn sli off and run just 1 card, crysis lags. So I notice 8800gts @1440x900 is NOT overkill.
@ 1440x900... 3870 crossfire works perfectly for me i can max out all the games i play ( except for crysis lol ) if i run 1 card then i still get decent performance but it will get a bit chuggy at some points in games.
Yea. That dawned on me after I made this post.
Haha, thanks guys. My bad.
I'mma just get a 8800GT lol. That will handle my gaming. Assn. Creed, Spore, etc. lol
I run the same resolution with my 8800GT 512mb, every game runs flawlessly (minus Crysis if I enable AA).
I was just looking at prices for 8800GTS.
Now it's really about the HD3870 or the 8800GT.
Off to GPU Review
Shame I wont be running DX10 thought...
Get the 8800GT, just be sure its the 512mb. You can usually find it for less than $200, sometimes closer to $150 if you get rebates.
Yea. I was at GPU review, and even thought the ATI seems to beat the nVidia spec wise, all the reviews kill that poor ATI card.
Prices on 8800GTs are right near $150. That's what I'll be getting. I figured the 8800GTS 320 would be mroe powerful, I was wrong apperently. the 640 seems to be worth it though. It's more then I want to spend.
