I am looking to replace my trust old Samsung 226BW to take advantage of my setup.
I am looking to upgrade to a mid-range monitor that will work well with gaming. I would love to go IPS, but there does not seem to be many options with the 1 to 2 ms response times, so a good quality TN will be acceptable. I am looking for your thoughts. I am okay with either 24” or 27”. I would much prefer the 27” monitor or a 16:10 ratio 24”. I also prefer a matte display.
I have been looking at the ASUS VS278Q-P (or similar): http://www.asus.com/us/Monitors_Projectors/VS278QP/
The reason for the budget is that this is going to be a gift to me from the wife, so I need to keep it reasonable
My current setup is a custom built i7-3770K, ASUS P8Z77-V Pro, 2x Nvidia 660Ti SC 2 GB in SLI, 16GB Corsair Venegeance 1866, 850 watt Corsair 80+ power supply, Windows 7 Pro.
My secondary question, will I be able to run my older monitor with its DVI-D input if the new monitor is hooked up via HDMI?
Thanks!
Thanks!
