Gaming Machine -- Build out Help
rajs
Hi -- I have a Dell 9100 Dimension and am considering returning it since I am not getting the perf I would like outta it -- Intel Pentium D 820 2.8 GHz w/1GB RAM (533 rating), 160 GB SATA HD, Audigy 2ZS, Dual Layer DVD Burner and nVidia 6800 GeForce Card and 802.11 USB Card. The total cost was ~ 980 bucks.
I ripped the 6800 card out and put in a eVGA 7800GTX card in but don't like the overall perf of it in BattleField2 (1600x1200 res with all setting at high) and also the 3dMark05 was ~ 6500 rating.
Was thinking possibly the CPU isn't keeping up with the new graphics card. I am willing to return the Dell Box and all but would like suggustions for ~ 1000 bucks or as cheap as possible at least ... for better performing machine that I can buy or I can put together top to bottom:
I will keep the 7800GTX card -- which I've been able to easily OC to 491 Mhz (CPU) and 1300 Mhz (Memory). I've seen in RivaTuner show the CPU speed up to ~ 525 MHz while in BF2 on the card (not sure how accurate that is though) -- but still have seen BF2 stutter a little at times. I am also keeping the Dell 2405 24" LCD which I was able to pick up for ~ 733 bucks taxed and delivered to me. I am also keeping the Logitech 518MX mouse and Nostromo Keypad I picked up else where.
So I guess what would you recommend as a full system from somewhere or something I can put together that has the following at least (any specific recommendations of which explicit model / part number would really help)
CPU (should I consider the Intel Pentium D or Pentium 4 or AMD Athlon 64 3800+, etc)
Motherboard (Should support the CPU above and support a PCIe slot for the 7800GTX video card)
Power Supply
Case
Keyboard
DVD Burner - Dual Layer
Floppy Drive
802.11 Card
SATA Hard Disk of at least 160 GB @ 7200 RPM
RAM -- please suggest based on which CPU / MB you recommend
Sound Card (I like using very high quality headphones that are ~ 500 bucks so am not worried about 5.1 speakers configs, etc)
And anything else I might've missed as a component that is needed.
Thank you VERY MUCH for your thought and assistance.
- raj
You want us to pick out ^^^ that
For 1k? That's not bad, as you've already got a 7800gtx, let's see...
http://secure.newegg.com/NewVersion/WishList/wishlistCurrent.asp?BundleExist=N
Edit: there's no mobo, I didn't know if you wanted an SLI mobo or not, if so maybe you might like to look at the seasonic 600w psu as well. I didn't know about OC'ing either, hard to pick a mobo. That sound card has a $50 mail in rebateso $60-70 for that card was nice I thought.
