Gaming Machine - $500 Budget
Chriz
Hey guys I'm trying to piece together a gaming machine for a family member. Budget is around $500. Mostly will be playing tf2 but would also like to be able to play starcraft 2 when it comes out. Thank you for any help! :D
Gaming, TF2, Source engine, Starcraft2
Budget: $500 - Would like to keep it as cheap as possible while still getting reasonable quality parts.
3) Where do you live?
MO, USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, MOBO, RAM, PSU, HDD,
LCD ONLY, Possibly Case depending on budget
6) Will you be overclocking?
If the parts allow for it, not a huge priority
1680x1050 resolution.
Within a month or two.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Ethernet, sound, nothing fancy
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
64 bit
Excellent build! But there's still the question of video.
The poster didn't mention the need for a video card, but at the same time, he didn't infer that he had one to reuse.
yea i am wondering the same thing ... cause if the OP does need it my build is out the window
It's not over. Let's combine brainpower, and get a build that's well-balanced.
$215 Intel Core i3-530 Clarkdale 2.93GHz + GIGABYTE GA-H55M-UD2H
$55 CORSAIR CMPSU-400CX 400W $15 MIR
$50 SAMSUNG Spinpoint F1 HD322HJ 320GB 7200
$89 OCZ Gold 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 $10 MIR
$99 POWERCOLOR] AX4850 512MD3-PH Radeon HD 4850 512MB NOTE: you can get the 1GB model here for $10 more.
Total - About $510, before $25 MIR. And the video card performance is only a step behind the 5770 in the other build.
Wow, great builds, yes I do need video, I can't believe i forgot to add that. thank you all for the help!
And now, you have to decide which one to go with.
The Core i3 will toast the Athlon X4 core in games and light multitasking. Purely parallel loads will see it slightly losing, but staying competitive. This is why I like to push it as an excellent entry-level gaming chip: it does everything well - single-threaded, multi-threaded, and smooth task-switching.
The 5750 will give you very little framerate bump over the 4850 1GB (%5 or less), and has a $35 premium attached to it just so you can get DX11 support. IF you only have $500 to spend on a system, a feature like DX11 is a waste. Upgrade to DX11 when you can spare the cash.
Both platforms offer you a CPU and GPU upgrade path, so the choice is up to you.
Whichever build you go with, don't get the F1 320GB for $50 when you can get the F3 500GB for $55. ;)
I think we can agree on this. I was just cutting corners as tight as I could to hit $500 :)
I would spend the $10 extra for the 1GB 4850 also. That would bring you to $525 - $25 MIR.
