BobTheBuilderr0x
- Jun 19, 2005
Anyone able to suggest a good gaming laptop that can run most games on high settings, looking to spend around 1300-1400$, thanks in advance!
How are the sagers? Heard good and bad about them. Also do you got a link to that NP8275?
In my rather long experience in owning Sagers, Asus', AWs, and MSI (and Dell and Gateway) gaming laptops, I'd say the following:
Overall, I've had excellent experiences with both Sagers and MSI model. It's really more about the reseller than anything else if you have issues. Powernotebooks, XoticPC and Mythlogic are terrific dealers, in my experience. Just go to one of those sites and configure an NP82xx model with an 8970m (same chip as a desktop 7870/270x)
- Build quality on the Sager/Clevos and MSI are about the same. Not as good as Asus or AW, but passable. Asus and AWs have better quality builds, but definitely not worth the premium (it's unfortunate Asus has decided to go with ultra high-end pricing because they used to offer the best quality for the money, IMO - w90vp, I'm looking at you)
- Cooling is better hands-down on Sagers (at least when comparing NP82xx models vs GT60. I've owned both and cooling was a marked constraint on my GT60.
- Design is more about preference, but I prefer by far Sager/Clevo's subdued looks compared to MSI's more bulbous dormroom toy design. IMO, steer clear of Sager's flashier designs e.g. 9280 (with the "winged" touchpad lighting) - they're basically the same chassis as the other models with annoying LEDs and "gaming" finishes. But similar to build quality, neither are as good as Asus or AW
- Keyboards on MSIs are superior, Sager/Clevo keyboards are usable but have some flex and some downright bad key placement
Alrighty. Thank you for the suggestions and the break down. I got an ASUS G75VW that I enjoy, but not really running as well as I hoped for BF4.
I'm not sure about all Sager laptops, but I do want to comment that the ASUS ROG design with two fans and individual heat sinks for the CPU/GPU is far superior to any laptop I've ever used that uses a more traditional cooling system. My G46 is very quiet and cool while my GF's Sager NP7330 is hot and loud. Of course, the NP7330 is rather small so I'm not sure if the larger Sagers employ more aggressive cooling or not.
Used alienware is your best bet. There are always some available, i just picked up a barely used (2 mo old) AW18 4700,16GB,SLI 765's 400 nit screen, 10 mos waranty for $1400. Ive been buying AW since the 900D, and while they can get pricey nothing is better. the Clevo based laptops that are sold by 100 re sellers are decent but build quailty isnt what it used to be and there plain ass ugly. Msi are good but ugly as hell too. Asus used to be the best bang for your buck but they started to not hate money anymore.
But personally ill always Side with AW, the deals are out there that make them affordable you just have to look, or haggle with Dell, you can always get them to take a few hundred off if you actually call in.
http://www.amazon.com/MSI-GT70-2OC-...76689&sr=1-1&keywords=msi+gt70#productDetails
http://www.amazon.com/MSI-Series-GE...B00CU9GKU8/ref=psdc1_t1_B00CU9GLUM_B00CU9GKU8 - This has more ram then the above, but a 765 and not a 770M.
http://www.xoticpc.com/sager-np8275-clevo-p170sm-p-5913.html?wconfigure=yes
Upgrade the ram from 8gb to 12gb, upgrade the hard drive to the 1tb, and get a 120gb ssd came out to about 1419?
Additionally, it's no where as easy changing out parts on AWs. Moreover, Dell has started doing some iffy stuff with limiting power throughput on their new models e.g., AW 18 which limits your ability to OC.
Source? I've owned an M17x R3, and two M18x R1's. I disagree that it's difficult to swap parts out in one. In fact I'd venture to say it's the easiest of any brand just looking at Youtube tutorials of other brands.
Lastly, Dell isn't "limiting" any power throughput. There simply isn't enough juice out of a single 330w brick for two 780m's and an XM chip to see extreme overclocks. That goes for any brand.
Don't get the MSI GE70, IMHO. For a few hundred bucks more you can get the GS70 which ships with an SSD in it, killer rather than realtek networking, much thinner and all aluminum case, and a better battery which gives you decent life out of it. There are a few other things as well it does better.
The downside is that the GS70 lacks an optical drive and VGA out... though with dual mini display port and HDMI out should have you covered.
Also the GS70 comes in OEM/barebones, so many retailers will sell you a vastly cheaper version that ships with just 8gb memory and a single 2.5inch drive, just keep in mind the chasis is stuck at 2ram slots, 1 2.5 inch drive, and 2x msata ports.
How much more? And a lack of vga out is fine. Really trying to stay within a 1300 - 1400$ budget
Actually a special dual brick system was developed by the community for use on the m18x r2 which works great. However the motherboard on the new 18 is clamped to 330w meaning while the dual brick system works the motherboard refuses to draw over 330w.
Also certain cpu settings are not controlled properly meaning it's very hard to get the 4930mx not to throttle.
I've owned three m17x R1/R2s, and an m17x R3; two m18xs and a host of other AW models e.g. m14x, m11, m15x going back to non-Dell days. On each model, you invariably need to remove multiple parts of the chassis to replace parts. Some of the fittings are tight and require following multiple unique steps to remove the pieces without damaging them. It's not "difficult" per se, but definitely takes more time and effort than in most Sager or MSIs where it's pop off the back cover and go.
You're right on the power restriction: Dell's not limiting the amount of juice going to the laptop. What they have done, however, on the 17 and 18 is locked the bios so it's virtually impossible to do any modding for higher OCs.
I've read up on the dual brick trick, I was simply stating out of the box with a single brick. I was not aware that on the R2 the motherboard was unable to draw more than 330 watts. It makes sense if you look at it from Dell's point of view, but unfortunate for enthusiasts. Thanks for the clarification!
I take back saying that the AW is the easiest. Considering the MSI chassis has several different variations and barebones it only makes sense that it would be easier. I guess I didn't agree with it sounding like the AW was difficult in the first place. My M18x's were the first laptops I had ever taken apart and upgraded and I found it fairly simple and straight forward.
Right, but we're essentially considering a couple models for gaming: the MSI GE70, GE60, GT60, GT70, the Sager 82xx series, or the AW 17 and 18. Of those, the AW models are definitely not as straightforward to get to the juicy bits
Asus is whole other ballpark where they tend to solder on the chips in the gaming laptops which makes upgrades virtually impossible.
The alienware will be more accepting of future cards though.
This is hit or fucking miss. You shouldn't buy a laptop in the hopes of upgrading the GPU later, you're rolling the dice.
