Gaming Laptop for under $1000
desh
I'm trying to pick out a gaming laptop for my nephew. I quickly put together an HP dvt7 for $800, but I'm not sure how "future proof" it is:
• Intel(R) Core(TM) i5-460M Dual Core Processor (2.53 GHz, 3MB L3 Cache) with Turbo Boost up to 2.8GHz
• 1GB DDRD3 ATI Mobility Radeon(TM) HD 5650 switchable graphics [HDMI, VGA] - For Dual Core Processors
• 6GB DDR3 System Memory (2 Dimm)
• 500GB 7200RPM Hard Drive with HP ProtectSmart Hard Drive Protection
• 6 Cell Lithium Ion Battery (standard) - Up to 5.0 hours of battery life +++
• 17.3" diagonal HD+ High-Definition HP LED BrightView Widescreen Display (1600 x 900)
• SuperMulti 8X DVD+/-R/RW with Double Layer Support
• HP TrueVision Webcam with Integrated Digital Microphone
Is the Radeon HD 5650 a decent gpu? It's also only 1600x900, and the core i5 is first generation.
Edit: I Think this Sager might be a better deal for $930:
Sager NP5175 / Clevo W170HR
- 17.3" FHD 16:9 "Glare Type" Super Clear Ultra Bright LED Glossy Screen (1920x1080)-
- 2nd Generation Intel® Core™ i5-2410M, 2.3-2.9GHz, (32nm, 3MB L3 cache)
- nVidia GT 555M 2048MB PCI-Express GDDR3 DX11 with Optimus™ Technology
- ~ 4,096MB DDR3 1333MHz Dual Channel Memory (2 SODIMMS)
- ~Combo 8x8x6x4x Dual Layer DVD +/-R/RW 5x DVD-RAM 24x CD-R/RW Drive w/Software
- ~ 500GB 7200RPM (Serial-ATA II 300 - 16MB Cache)
- Built-in 802.11 Wireless B/G/N - Stock Wireless Card + Bluetooth
- Built in 2.0 Megapixel Camera
I'm thinking the battery life might be lower on this one, but I'm not sure.
wow, so sager is a better brand than HP? What's so bad about HP?
sager is known for building gaming laptops, hp is not. Hp is okay their build quality between models is hit and miss from what I have seen the last few years
I would go with the Sager because of the 2nd gen Sandy Bridge CPU alone. There are some quad cores at the same price point check out xotic.
