gaming issues with vista x64
computermod14
alright, heres the rundown...
I'm currently running the SLI config in my sig. When I ran the stress test in CS:S with one card, average was 125. Enabled SLI and avereged 174. Now yes thats better, but not much. During gameplay with one card, fps never dropped below 100 on Dust 2. With SLI it drops below quite a few times.
Also in source, after about 5 minutes of gameplay, fps just completely bogs to 25 fps, and jumps to about 150 every 2 seconds in SLI mode....very odd.
As far as BF2, the game just crashes when I try to join a server, right after I double click.
ANY help is MUCH appreciated, thanks guys.
We can't help you unless we know at least your rig specs or what kind of drivers your using. Maybe then when you do :).
well, for some odd reason my sig isnt showing...thank you :).
EVGA 680i SLI
Core 2 Extreme Q6700
4GB Corsair XMS2 Dominator
SLI 7600GTs
I'm not experienced with SLI myself but I do recognize that you should get higher fps than this especially the really low fps. If you can I might suggest you to try different video drivers it probably explains with BF2 isn't even running.
i thought sli in vista x64 was still buggy as hell and bad performing?
well heres the latest...i switched to windows xp x64 which i tried staying away from and it seems excellent right now. ran the stress test in css and got 227 so im happy. still would have liked to run vista :(
It honestly doesn't perform all that bad. I'm currently running BioShock @ max settings (without anti aliasing) @ 1900x1200 and get a solid 30 fps. And my 3d Mark score is only 10% lower than that of a similar PC on XP.
As for bugs, any new OS will have them. Although it is kind of sad when 3.9 GB of my RAM and 9 GB of disk cache is being used on an empty desktop after running some games. Definately some memory cleanup issues.
No it isn't an issue. Vista uses your RAM that you aren't using to prefetch programs and do various tasks in the background. Why would you not want the operating system using your memory when you aren't using it??? Programs load quicker and your PC is snappier for it.
I've found that most of my SLI performance issues on Vista x64 were ironed out by the 158.45 drivers. Future releases have only improved 158.45 performance, although TDR issues came back briefly with 163.11. Before 158.45, only some games seemed to benefit from SLI, while others that should have (such as FEAR) clearly didn't. Now my gaming experience is pretty much on par with what it would be on XP.
The tricky thing about Vista is that a lot of the hardware subsystems were rewritten, especially with how drivers talk to the OS in kernel or user space, and how memory is mapped to drivers and programs. There's also this nasty protected content path system that some claim to be behind many of the driver-not-responding issues people are having.
The bottom line is that everyone is bound to have differing experiences with the OS, at least for the first year of its life. Each driver revision can be expected to fix different problems on different rigs, and hopefully going forward the gaming experience on Vista will become more consistent than it is across XP machines. I've personally found that the OS and drivers have matured greatly over the last 10 months, and I believe that to be the general consensus among many, if not most users.
Mark.
