Gaming Headsets
Cybiker
I've been looking at picking up a headset for use in games such as Counter Strike and others...and I was wondering if it's possible to have only the voice come through the headset, and the in game sounds to come through my speakers, such as on Xbox Live...I have onboard audio and an Audigy sound card...Would it be possible with this setup...or not because i have to disable the onboard audio in order for the audigy to work? What about a USB headset? For the main game im looking to use this for it will be a separate program for sound...so would I be able to choose the voice to go to the headset? Thanks for any help/input...
I think you can get another cheap sound card and select the audigy for the game which would be hooked up to your speakers, then the other sound card would be hooked up to headphones and you would select that card in TS or Vent or whatever you use.
