Gaming Headsets - USB or Standard?
danzaman
Hey guys,
I am about to purchase this headset from bestbuy which is a USB headset:
http://www.bestbuy.com/site/olspage...dset&lp=12&type=product&cp=1&id=1177717627748
However, I was told from someone that I shouldn't buy a USB headset because of the sound quality which tends to be worse than the standard mic jack headsets. Does anyone know if this is true or if the headset I'm looking at is nice? I want to spend $50 max and find the nicest headset I can for occasional gaming.
Thanks,
Dan
USB headsets act as their own soundcards, so if you had a nice soundcard thats a big strike against them. Your cpu utilization will be higher with usb sound, which may or may not matter. It mattered on my old machine which was borderline playable before i tried usb sound.
The usb headset i got had absolutely horrible sound quality. It sounded 8bit/16khz or worse. Im sure not all usb headsets are this bad, but this one completely soured me on usb headsets. I think the one i had was an altec lansing.
I would recommend the Sennheiser PC 150's. Picked up a pair recently. They use a standard mic jack (can't stand USB headsets myself). Comfortable for hours, even with glasses on. Sound good and well within your price range to boot.
-EDIT- May have to order them online or see if somewhere else local to you has them in stock. Seems CompUSA has a "Limited Company Stock" and only 5 stores in the US have any left.
-EDIT2- Looks like Sennheiser has come out with a new version. Would explain CompUSA's situation. Newegg has 'em.
Agreeing with this, very good headset. I tend to stray away from USB headsets due to me having an SB Audigy.
I have an X-fi and use it for my everyday audio but when I am away from my main desk (Lanning at friends or something) I don't bring my whole 5.1 and I just use a set of Logitech USB headphones. I like them and they work very well.
CPU usage is not really that bad and has not really affected performance in games.
I use my USB headset for vent, Its annoying always trying to adjust your game so you can hear vent and the game well. With a USB headset you can get vent to run through the head set and your games to run through your computer speakers, thats the main adavntage of USB for me.
Standard jack Sennheiser, the best one your budget allows.
I own a mere PC130 and it sounds great and is very comfortable to wear too.
And why a Sennheiser you may ask?
Easy, they're not a general electronics company like (for example) Logitech, these guys are specialised in headphones and microphones, they don't do anything else.
I would check out the Sennheisers pc-150s. Mine still work perfect after 4 years and I love them.
Man, I always forget about the Senntheisers when I look at headsets. I'm definitely going to check out that 151 set.
There is a Plantronics Gaming headset they sell at Best Buy. The have standard 3.5mm jacks for Mic and Headphones, plus a USB dongle that you can plug the 3.5mm's into to turn it into a USB set. It is the most comfortable headset I've ever worn, the sound quality could be better but its not bad either. The mic quality is excellent when used via USB. You could probably use just the mic via USB and the Headsets via the 3.5mm jack, so you get the best of both worlds :)
http://www.bestbuy.com/site/olspage...aming&lp=1&type=product&cp=1&id=1186004297578
A lot of times since they use their own internal soundcard if you have speakers and a headset you cannot use them Concurrently. Also I have heard that if you unplug it to use your speakers but then need to plug back in while in game it doesnt always work.
Sound quality I have heard mixed things on but I chose to stay away when I had to replace mine recently. Was a tough search as most of the decent looking (comfort etc) were USB. Finally setttled on the Turtle Beach HPA 2.
