Gaming computer upgrade finished!
Pictures below for now, will post specs later:
View: https://www.youtube.com/shorts/wMJQig-vWQw
View: https://www.youtube.com/watch?v=5nQhh2cimCw
View: https://www.youtube.com/watch?v=iYjBjWB3IAU
Hardware specifications (New):
Asus TUF-Gaming X570 Plus Motherboard
AMD Ryzen 5 5600x CPU (3.7/4.6 Ghz)
G.Skill Ripjaws DDR4 3200Mhz RAM (32 Gb)
Hardware specifications (Old):
Asus X99-Dekuxe Motherboard
Intel Core-i7 5820k CPU (2.9 Ghz)
Corsair Vengeance LPX DDR4 3200Mhz RAM (32 Gb)
Shared components:
Asus GeForce GTX1070 Turbo
Creative Sound Blaster AE-7
Nidec Servo Gentle Typhoon Fans (2150 RPM)
Custom Watercooling
Seasonic Focus GX-850 PSU
Shared components:
Custom Watercooling
Hey! Why did you decide to change/upgrade the RAM?
Honestly? Peace of mind since I wanted all of the parts to be compatible with each other.
your existing kit probably would have been fine, and you should have bumped to 3600. see if you can get that 3200 kit to run at 3600 to max out your infinity fabric.
Good tip, that's what I did on mine, bumped 3200 RAM to 3600. No problems with stability, no any other adjustments were needed to get it working.
Thanks for the tips! Will try that tomorrow night after work.
The question is whether you will succeed on a 3600mhz clock cl16 from 3200mhz, maybe with relaxed latencies, you should have immediately bought a 3600mhz cl16... but if it doesn't work for you, 3200mhz is perfectly fine, it's not a big gain with 3600mhz.
Cpu 5600x is still holding you back, you need a stronger cpu for 3600mhz and 32gb ram.
I built at least 10 systems on B450 boards and 5600X with 32 gigs at 3600MT and none of them faltered at that memory speed. The memory kits were all GSkill kits though so no crap modules to contend with.
