Primarily gaming and hosting game servers while gaming. Occasional video encoding
$1100 is preferable but if the upgrade is worth it, then up to $1300
USA, FL, Orlando-ish
Case, Motherboard, CPU(Ivy or Sandy bridge), RAM(12GB+), Hard Drive(640GB+), PSU, Video Card that supports dual video out (hdmi x2 or hdmi+dvi or dvi x2).
I am re-using keyboard, headset, mouse, monitor
6) Will you be overclocking?
Not likely.
1920x1200 27"
Within a week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Spare PCI-E slot for future improvements, USB 3, Onboard video would be nice as a backup but not required
Yes, Win 7 Pro
I hope I didn't miss any parts.
Not likely.
1920x1200 27"
Within a week.
Yes, Win 7 Pro
