Gaming
2) What's your budget? Are tax and shipping included?+
$1000 without tax and shipping and might go over my budget a bit for better stuff
3) Which country do you live in? If the U.S, please tell us the state and city if possible.+
USA, Miami, fl
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.+
CPU, motherboard, ram, videocard, harddrive, power supply, case, Windows 8? Sound card, cooling system/fans, dvd drive,
5) If reusing any parts, what parts will you be reusing? None
6) Will you be overclocking?
not sure
Need to buy one unsure of what size to get only focusing on build atm
In about a month or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
no
If I left anything out I'm sorry I'm a noob never built a pc this will be my first. I wanna be able to play games at highest settings I play a little bit of wow and just started elder scrolls online. Might also play battlefield and star wars the old Republic and more. Any help will be highly appreciated
Gaming
USA, Miami, fl
not sure
no
