GameStop has had Gamesticks for $20 for a while now. They're Android sticks that come with a controller, equipped with a dual core CPU and Mali 400 Graphics. You can install CFW on them and sideload apps. The controller is pretty bad but if you wanted to you can use the controller as a gamepad for your Android tablet or phone. The controller is 8 bucks at GameStop.
http://www.gamestop.com/android/consoles/gamestick-stick-and-controller/109154
