Games will not install??? HELP!!!
>WP< $lipKnot
Return to Castle Wolfenstien and Hitman2 will not install. I can install many other games. Why will these games not install. After I tried to get these 2 games to install I installed Delta Force Black Hawk Down and Max Payne just fine. Here is my system. Help me I want to install these 2 games. Here is my machine specifications.
Asus P4C800-E Deluxe
Antec TruePower 550 PSU
P4 3.4c Northwood OC'd to 3.8
Coolermaster Jet 4 Cpu Cooler
BFG 6800 Gt OC'd to 400/1100
Audigy 2ZS Soundcard
2 80 gig SeaGate Barracuda's
200 gig Western Digital Caviar Se
LiteOn 8x DVD+RW
Generic CompUsa 52x Cd Burner Dvd-Rom Combo drive
2 Vantec hard drive coolers
2 80mm Antec blue led fans
1 60mm Antec fan
1 Vantec 2xfan Blue led fan card blowing on my 6800Gt
1 gig or Geil Ultra platinum DDr
2 blue cathode lights
I have my UDMA set to auto and my PIO set to auto. Should I change this.
Also DVD movies play just fine too.
I AM FRUSTRATED HELP! :mad:
How exactly do they NOT want to install? Error, crash, nothing?! what!
Duh, we're supposed to guess! Don't you know that by now? Do you really expect him to give any useful information at all? That wouldn't be the way of the forums! :D
It loads the autoplay menu and then when I click install I get nothing. It then stops responding.
My advice would be to hold shift as you put the CD in (to temporarily disable Autoplay), then go to Start-->Run and type x:\setup [enter] (x is your CD drive letter)
Thanks for the reply. I just restarted and went into safe mode and installed them that way. DOH! I do not know why I did not think of that before.
motithejrt said:
Dude, quit trying to use ISO's you downloaded and go buy the real game.
For your info Brainiac they are the original store bought versions not iso burned crap.
I dont do iso crap.
With a rig like this you actually think I would not spring for the real deal?
I dont do iso crap.
Your computer specs have nothing to do with the likelihood of you using real games or not. You need to realize many threads we get, exactly like this one, are due to people trying to run wared or cracked games. You just have to make it clear from the beginning, it's the real retail CD.
Thanks for pointing that out ... you'd think "with a rig like that" you wouldn't have problems installing a fuckin game... simmer down teapot.
I found out that my Antec TP 550 was the culprit. It was manufactured poorly and was not properly powering my optical drives. Bought the Enermax 651 550watt and have not had a problem since.
