So I was playing some Battlefield 2, and everything was going great. About 30-45 minutes in, my computer just locked up. The screen froze and the audio started looping. Task Manager would not come up. Only thing that would fix it is a hard reset by the button. This has happened several times.
Any idea what could be causing this problem? I am running an AMD64 3000+ (stock cooling, no overclocking, around 43C idle/60C full load) and a BFGTech 6800OC (their stock overclocking, running 51C idle, not sure full load). My case temps run around 30-35C.
Is it heat? A driver issue? A hardware malfunction? What could the problem be?
