Ohmycaptain
- Jul 10, 2011
EDIT: Nevermind, figured it out. Turns out you have to Enable and then Disable 3D mode twice with Toasty's then reboot.
TIP: Improving Convenience, Stability & Eliminating “Control+T”:
Once you’ve verified LightBoost works (Step 12), and the registry tweak was already installed (Step 4), you can make LightBoost “stick” by going to nVidia Control Panel and disabling “Enable Stereoscopic 3D” (clear the checkbox in Step 8). If the screen did not flicker when doing this, LightBoost is still enabled even after disabling 3D!
– Games launch in 2D without needing Control+T
– Driver stability is improved in this mode, less freezing occurs.
- VSYNC OFF now works much more reliably, reducing input lag, fps higher than Hz.
(Note: Some games may automatically switch resolutions; make sure it stays at 120 Hz)
