Games in DirectX 11???
VE2007
Can someone tell me how to run a game like Dirt 2 in Directx 11 because all my games start with direct X 9?
Sorry for the stupid question :eek:
which windows version are you running =p
Aww c'mon man. Right in the sig hehe. :p Windows 7 64bit.
You can check what version of DX you have,
Click Start button
Click Run (skip in Vista/7)
Type: dxdiag
Press enter
Look for Direct X version line in the dialog that opens.
Click Start button
Type: dxdiag
Press enter
Thanks Mate,
I looked in DirectX Diagnostic Tool under DirectX Version and it's DirectX 11 :)
You should be good then. As mentioned above, a lot of the DX features are graphical improvements/rendering that are either added/removed depending on what DX you have and your video card. So they won't be labeled as DX11 but you will probably notice a difference between the game if you had say DX11 vs 10 or 9.
