games dont work after CMOS reset HELP!
takimbe
so my OC failed and i had to reset my CMOS. afterwards, windows boots up fine, but none of my games work anymore. UT3 even gives me the BSOD! do i have to reinstall windows XP pro sp2? or just the games. any help is appreciated! im running at stock right now btw
It is possible that your memory timings have to be manually set. Memory might be the culprit.
I'm guessing memory too. Check the timings and voltage to make sure it's set to its recommended settings.
i think it was the memory. ive been running stable ever since and no more BSODS! thanks guys!
