Game wont render in fullscreen
n370zed
I just got WoW: MoP and the game resolutions wont fit my monitor. At 1920x1200 and 2304x1440 the picture is like in the middle of the screen with and inch or so on all sides of the monitor. I cant adjust it to fit the screen anymore. This is the first that this has happened. Every game I have it all scretched to fit on the screen properly. Strange thing is that when I choose Fullscreen Windowed it adjusts accordingly. I tried setting the fullscreen resolution with my desktop at 1920x1200 @ 85hz but it still wont let me adjust it to fit the entire screen. Any input is very appreciated.
My specs are:
i5 2500k @ 4.5ghz
AMD HD 6950 2gb (with 12.8 drivers)
8gb ram
128GB Samsung SSD
sounds like it is your monitor.
make sure monitor is set to fill the screen and not by per pixel or it will be tiny in middle.
make sure you set the game to use your monitors res.
make sure it knows the native res of your monitor
