game problem .. PLEASE HELP
MuDDoG
I just bought EVGA 6800gt from newegg..... my games get slow fps and are slughish.... I reallly hate this..... in css its realy bad .. i play on my rec settings and its slow .. please help me!!!!!! i dont know what to do :( my friend has almost same pc and his games run great!!!
I get good scores on benchmarks but games are bad .. please help!!!!!
My Nvidia drivers are 71.25
my scores
3dmark01 16,500
3dmark03 10,850
3dmark05 4,781
Aquamark 55,600
-CPU 8,700
-GFX 8,900
CSS test 42FPS on everything HIGH 1600x1200
my specs
LINK ON THE RIGHT SHOWS THE SPECS.
WINDOWS XP PRO
P4 3.0Ghz [L=CPU ]http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=687508[/L]
Asus P4C800-E Deluxe [L=MOBO]http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-464&depa=0[/L]
1024 MB pc3200 (running in DUAL CHAN) [L=RAM]http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1071020&Sku=ULT31664[/L]
EVGA 6800GT 256MB [L=VIDEO CARD]http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-203&depa=0[/L]
Sound Blaster LIVE! 24bit [L=Sound CARD]http://www.soundblaster.com/products/live24bit/specs.asp[/L]
Maxtor 160GB 7200 RPM 8mb cache [L=HDD]http://www.staples.com/Catalog/Browse/Sku.asp?PageType=1&Sku=504516[/L]
Antec 450WATT [L=PSU]http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-920&depa=0[/L]
05 looks about right, not sure about the others. Remember to install the latest chipset drivers, etc.
Did you have a different card before (like an ATI)? If you did or if you recently updated your video drivers did you use Driver Cleaner first to get rid of the old ones? I recommend the official 66.93 drivers btw and will never trust a beta driver.
03 and 05 look about right. Your 2001 and source test tell me there's a problem with your motherboard/chipset/cpu though. Have you installed the drivers for them? Otherwise something else is going on, but I'm not exactly sure what's up.
yes i had ati card before .... but i used driver claener and got rid of the drivers and installed the beta drivers .. my score was in mark05 3200 with drivers off the nvida site .. but now when i got the beta its 4800
