In the name of science I figured I would see how much voltage is created when using a aluminum rad. and copper water blocks.
Test Method:
Unplug computer power from source (wall socket).
Wait 15 minutes for energy to dissipate/equalize (yes I know there are capacitors).
Using a multi meter put positive probe on unpainted surface or a spot on rad where there is continuity. Eg screw going through bracket into rad. bracket.
Put the negative probe onto a bare spot on the copper water block (may need to scratch surface if oxidized)
Measure DC voltage.
My System, Thermaltake Armor LCS case with integrated water cooling.
Aluminum Rad
Copper Water blocks
Results:
My CPU water block creates 51 mv, VGA water block 2 mv.
This isnt a whole lot of voltage but it seems to prove that aluminum and copper dont mix and was just interesting
Im not sure why the VGA block voltage is so much lower than the CPUs. However its interesting to note that I can see more products of corrosion (white salts) through the clear top on the CPU water block as opposed to the VGA water block.
I'd be interested to hear if those of you using copper/copper get any voltage readings.
Test Method:
Measure DC voltage.
Aluminum Rad
Copper Water blocks
Results:
