Sodapopjones
- Aug 22, 2012
I know I'm not the only one, I'm not sure if it was the earlier batches, but seriously the fans are driving me up a wall....
Sometimes they sound fine, other times it sounds like the bearings are rattling and grinding, its weird.... There is vertical play with the shaft, so I'm not sure if its just the fans design, or if they're just going bad; I didn't really notice it getting louder till this weekend.
Its not really noticeable till after 55% usage and it gets really bad after that, it doesn't help my setup is nearly dead quiet using Cougar case fans and my PSU doesn't kick its fan on hardly ever.
I have no doubt an RMA wouldn't be a problem, I'm just worried I won't get a core as good as mine, since apparently the 2GB Galaxy cards are meh compared to the 3GB cards.
