Hi,
I had a raid0 running with a GA-X38-DQ6 but had blue screens and instability issues. I noticed a bios update that says "added support for Yorkfield". My cpu is a yorkfield, so I decided to update. Unfortunately, I think I didn't uncheck "clear cmos settings" or some option like that. Anyway, it reset all my bios settings when I updated the BIOS and thus cleared my raid settings. Now on boot-up it says that 3 of my drives are controlled by raid, but then it says my raid0 is failed and that one of the disks that comprises my raid is "non-raid" or something like that. My raid disks are plugged into ports 0 and 1 and the third disk that is says is controlled by the raid adapter is my standalone disk. Any ideas? I'm not sure what settings to select in my bios to know that I have my raid stuff set up correctly.
Thanks,
guitarfly
Thanks,
guitarfly
