Alright, well I have a Gigabyte GA-P35-DS3L Motherboard with an E2160 1.8ghz cpu. I have it overclocked to 3ghz by raising the FSB from 200 to 333. I have the memory ration at 2.4 so i can use my full 800mhz memory. I use 4GB of A-data DDR2-800 memory that is rated at 1.8V. For some reason my motherboard runs my memory at 1.99V instead of the 1.8v it's rated for and I don't see a way to change it. In the bios it gives me an option to add voltage to it if i set all my computers voltage controls to manual and set them myself.. but that doesn't help because i need to remove some voltage. Not to mention, if I set my voltage controls to manual, then i have to manually set the cpu voltage, which i want to automatically take care of itself sine it can. So why is my memory running at 1.99v instead of 1.8v, is it a bad thing, and is there anything i an do to change it?
- Mike
- Mike
