Need insight. Correct me if Im wrong here.
Win XP 32-bit is capable of addressing no more than 4gb of memory. The memory is to include ram on GPU as well. Natively, win xp 32-bit has PAE (physical address extension) disable by default (until service pack 2). If my motherboard will read 3 sticks of OCZ GOLD PC 6400 and will post properly, Im assuming my system is not over the threshold of memory and obviously is capable of handling it. So with 3 GB of ram installed xp 32 bit BSOD on me every time. Even with PAE enabled with the switch it still BSODs my ass. So if I have two 256 MB 8600GT in SLI could that be the problem? All DIMM pass memtest. Even when i bring my overclock down it still BSOD. All voltage's are the same as what's seen here:http://www.vr-zone.com/articles/Gigabyte_GA-N650SLI-DS4_650i_SLI_Review/4939-5.html
except the DDR2 Voltage which is set at 2.1 volts (i've also tried 2.3 and 2.4). I'm using f7 BIOS and FORCEWARE 169.21 (which i've heard could also be the problem). I'm using Service pack 3 as well. This is just about everything i can think of. I'm stumped. Any suggestions???
