GA-K8NSNXP-939 - nothing but problems :( need help!
cruz610
So I finally received the last piece of the new computer today, put it together, everything was going great up until the windows install; I get BSODed in the middle of it. WTF I'm thinking, OK 1 is no problem. Restart the install, same thing. Crap. So I format the drive (WD SATA 74gb raptor) again...and again...and again...each time its no use; it tells me that ntfs.sys has been corrupted or something to that extent. Lovely. I figure it may be the install cd; nope. Tried a different CD, same thing. To top things off, I cant access my floppy drive, for what reason I have NO idea :( I tried using a program that would boot to floppy (program is on a bootable cd) but it says device is not readable. BIOS reads it just fine and the cable is in the right way cause I switched it and got an error. WTF mate? So Im sitting with a shiny new computer unable to do anything with it :( I found an old 16gb ide hdd that I am currently attempting to install winxp on...FUN. if that is successful then maybe I can run some diags on the drive/board. I'm out of ideas tho, anyone else have some suggestions?
cliff notes:
1) got BSODed during winxp install; ntfs.sys is corrupted, happens everytime, cant install winxp
2) cant access the floppy no matter what, but drive is read through BIOS so i know it works
could be your memory, run it at 2.8v and decrease your timings to like 2.5,3,3,7 and see if that helps at all. May want to try only using 1 stick for the time being to see if that helps too.
Been doing research on this and it seems that ntfs.sys is the main issue. I installed winxp on an older hdd and formatted it to ntfs and surprise! BSOD again. so its not my hdd and its not the mobo/cpu. going to try installing win2kpro and see if that ntfs driver is any better. gah. so much to go through :-\
any ideas on why the damn floppy isnt working?
This may be a dumb queston but here it goes....
Are you loading the latest SATA drivers from a floppy disk? (I would think not since you mentioned your floppy isn't working) I would think it would require that. Also If the light stays on on the floppy drive then you have your cable reversed.
Might I suggest using another PSU and/or testing the current one? Also, use Memtest86+ to verify that the RAM is working properly.
Further, start with a basic system configuration (only the minimum number of devices installed) and try to get this stable first.
BTW, don't forget to reset the CMOS after every big change.
Figured out it was one of the sticks of ram :( Gotta RMA this stuff now, not too happy about that. Oh well...guess I will call newegg on Monday and see if they can do a cross ship or if not if I order a new one have it overnighted, I RMA this one and simply get credited back.
I am having the exact same problem but have found a temporary work-around.
Try moving the DIMMs to socket 3 and 4. I did that and it works MUCH better now.
I am running Corsair TwinX-1024-3200XL memory.
Definately not what I expected from a $220+ motherboard.
I tried almost everything before looking at memory problems. I tried pulling out all IDE stuff, and installing XP only with SCSI in the system, and then pulled out the SCSI, and installed XP with all IDE equipment. Right then and there I questioned how descriptive the bluescreen (stop 24, ntfs.sys) really was.
If you call Gigabyte, let us know their reply!
Hornswoggler said:
I am having the exact same problem...
(snip)
... Definately not what I expected from a $220+ motherboard.
It wasn't the motherboard's fault in his case. As for having the ram in the wrong slots, I had ram in slots 1 and 3 initially (wrong slots, you're supposed to use 1+2 or 3+4) and got a BIOS message that said something like "memory not optimized" but it worked fine and I was able to install XP. I didn't have dual channel when running with the wrong slots filled, but other than the speed hit I didn't have any problems. Once I switched it to the right slots it worked fine.
I don't think the GA-K8NSNXP-939 deserves this thread title. :p
