GA-H55N-USB3 slow memory?
munkle
My friend built a pc with this and an i3-530. He has 2x 2gb (4gb) ddr 3 1600mhz ram, although its running at 1333 right now. His pc scored 5.9 on the windows scale for memory, he thought that was really low since I get 7.5 on my x4 with the same amount and speed of memory installed. I thought it was because I use an atx board and the itx board is a little slower. Is that score something he should worry about?
Well, Windows performance scores are basically a joke in my experience, don't put much weight in them.
run a real memory benchmark and compare it to other published values for h55 boards. its the only way to know if you have a problem. comparing amd to intel is usually not straight forward
Is yours running at 1600 or 1333?
you already answered it.. its the i3 doing it.. I had the same thing & with the same memory I get a 7.4 on my Phenom x6 & actually had in the middle on my phenom 9850 be that I had before the i3
