The Cisco Kid
- Mar 31, 2007
And you have a Quad Core
Nope, no Quad Core here.
I was thinking about getting the q6600 and pushing it to 3.0ghz as anyone done this with this motherboard yet and was it done with just air cooling? Thanks
He wants to hear about the quad not the dual you have Cisco Kid
I finally got an answer from Gigabyte (slooooww customer support....) about the 1:1 divider:
Here is my qustion:
"Is there any possibility that you'll soon add a sync./1:1 memory divider?
I know there are many waiting to buy the first G33 board that comes with this feature (like the P35 models). I myself took that chance and bought it, hoping you'll add it in the next bios release. If you have such a release planned, could you tell when it will be avaible?"
And their answer:
"From what I have heard there is a chipset "limitation" (Intel probably wants the more advanced users to buy P35 instead) on the G33 that it does not support 1:1 memory divider. In that case it will not be availble with a future BIOS update."
EDIT: I downloaded the manual for the ATX G33 board and there the mem dividers are not specified, so that didn't make me any wiser...
I would be throwing this right back in Gigabyte's face... do they an offical forums area that I am missing? If not I think I will email them AGAIN...
Read the first few pages of the thread. The issue is 100% performance. pvhk explains it. Higher mem = lower CPU speed.Can someone explain to me what the big QQ is about a 1:1 divider?
(I seem to recall back in the day with earlier p3/p4 you got slightly better performance with 1:1...but does it really matter now much anymore?)
Does anyone have examples or links to examples of real world performance differences between 1:1 and non dividers?
Or is it for something other than performance?
thx
So should I be using the 2.5 multiplier instead of 3.0??
Right now my FSB is at 312 x 9 and RAM is @ 936. If I use the 2.5 multi the RAM drops below 800...is this bad?
I'm also having trouble getting the RAM to run at it's rated 4-4-4-12 timings. CPU-Z shows it @ 5-5-5-? I can't seem to find where to change this, if we can?
Don't get me wrong, the system is running rock stable and very very quick, I'm just relatively new to OC'ing.
Thanks!
press ctrl+F1 in the bios and u can change the mem timmings
at 312 x 9, I thought the Ram @ 936 (3x) will outperform 780(2.5x) ? anyone could explain? thanks
No you'd better use ratio 3x if your rams can handle it! better performance
The "issue" with the giga is that high fsb means very high mem frequency (so you will be quickly limited by your rams and not the cpu)
Ok, I have a minor problem at the moment. I've tried to change my RAM timings from 5-5-5-15 to 4-4-4-12. The RAM is rated at 4-4-4-12. The system seems to be unstable when I do this and on reboot the Memory speed keeps coming up at 800mhz even with the 3:3 divider and the CPU OC'd @ 2.8ghz. Does this mean the RAM can't be OC'd @ 936 with it's normal timings or am I forgetting to do something else? I raised the over voltage to +.02, but can't seem to find where in the BIOS that says my RAM voltage. For some reason I think the default voltage is 1.8, but can;t seem to find that again My G.Skill runs @ 2.0-2.1v.
Thanks for the help!
Another example:
e6600 fsb@450, ratio 8x used (3.6ghz):
with the giga:the ram will be @1125 or 1350Mhz (not all rams will hit those values)
with the P5K-VM: the ratio 1:1 allows the ram to be sync @900mhz (more easy to reach)
No dice. Dividers are still set to "non-selectable" in bios. All it would take is for Gigabyte to flip a switch.Has anyone tried the F3 BIOS release on the 12th? I just saw it came out and can't try it cause I'm at work.
So we can see how high the board runs or to run the memory at a faster speed. I could run at 389, but then I would be missing out on the bandwidth of this RAM I paid for.I'm not an expert on overclocking or anything, but why would you use 8 x 450 instead of 9 x 400 on an E6600?
me said:Hi, I don't yet actually own a GA-G33M-DS2R yet. My decision to purchase one will be based on the answer to the following question.
From what I've read, the GA-G33M-DS2R does not have a 1:1 divider available, so you need DDR2-1066 RAM to overclock better. I thought this was a limitation of the G33 chipset, but I've also seen evidence that the Asus P5K-VM (using the same G33 chipset) has a 1:1 divider, meaning you only need DDR2-800 to achieve the same overclock you'd need DDR-1066 for on the GA-G33M-DS2R.
So the actual question is, does Gigabyte plan to release a bios update for the GA-G33M-DS2R that will enable a 1:1 divider? I'd love to purchase a GA-G33M-DS2R, but would like to be able to stick to DDR2-800 instead of DDR2-1066
Gigabyte Tech Support said:unfortunately this motherboard does not have the option for the divider.
We can request for the feature from our bios team, but it is not guarante whether if it'll be added
I sent them a long rant and explanation of why they were going to lose sales to the P5K-VM.Hopefully if enough people ask for it, Gigabyte's "bios team" will wise up and put the 1:1 divider on the GA-G33M-DS2R
Yup.keep emailing their tech people and DEMAND a 1:1 ratio divider - they have updated the BIOS once since launch so clearly they know its not perfect. I've sent mine today.
Send more, send them from any old email address but if U want it then you have to get off your arses and tell them!!
Depends on how you feel about warranties. Normally voltage is not an issue, especially on mATX board because you don't get enough to play with. However I have heard that some people are having their D9 die at 2.2v, so if your RAM is not rated for that... well it's your call. Put a fan on it and it should be okay. I would probably buy something better, because volts don't tend to help you get much further.PS: Should I try +0.3v or +0.4v on my memory, or do I really risk burning it out? I've never OCed memory before, and the danger colors on the .3 and .4 are worrying me Thoughts?
Hello
I've been reading your forum for almost one year.
I want to build SFF rig and thinking of buying this gigabyte mobo + e2140 and Ninja cooler. I need your help here. Will Ninja be OK? Does it fit on Gigabyte?
Thanks
