So I purchased this board to install a "different" OS (see sig), and it was working fine. Install went great, and I was dual booting with Win7 perfectly. 3 days after I get it, the lan ports both die completely, won't show up in windows, nothing. I RMA'd the board with Newegg, and 2 weeks later, I get the same issue. I called Gigabyte tech support, and we discovered the bios was corrupted, and both lan ports had mac addresses of gibberish, FFFFFFFFFFFF and ABABABABABAB.
That being said, I reflashed the bios and was back up and running until today, where the same damn thing happened! Now, I reflashed again, everything is up and running (again), but I can now replicate the problem... Every time I unplug the power cord from the system, the lan ports gets shot. Anyone have any insight as to WTF is going on here? Every other setting stays the same, so I'm assuming it's not the CMOS battery, it's just the mac addresses that change.
Edit: one other issue that's annoying me but isn't a huge priority... Windows experience index refuses to run on this system, since I installed the board. On the old RMA'd board, it would produce an error at the end of the testing, but on this board, it won't run at all. I click the button to start the test and absolutely nothing happens.
