GA-EP45-UD3P + E8500
Thomase-r
Hello,
I just got this setup in and my first attempt at overclocking (with this board and an E8500)netted fairly quick success at a solid 4.05 Ghz running a cool 43-45 under prime blend. My motherboard rev is 1.6 and I'm running G.Skill F2-8500CL5D-4GBK DDR2 1066 ram. I found a template on the web for this board and an e8400 and went from there. I would like to see if I could get 4.5ghz from it and have but Prime failed within a minute or so with these settings and 4.25ghz. Could someone suggest some changes? Thanks.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto or Fast
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................:.0.5
CPU Frequency ...........................: 4.05
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 427 Mhz
PCI Express Frequency (Mhz) .........:Set to 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control
CPU Clock Drive...........................: 800
PCI Express Clock Drive.................: 900
CPU Clock Skew (ps)....................: 0
MCH Clock Skew (ps)...................: 0
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 1066 854 Mhz (In blue not changeable)
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5 [5]
tRCD .........................................7 [5]
tRP'...........................................7 [5]
tRAS..........................................20 [15]
Advanced Timing Control
tRRD...........................................4
tWTR..........................................4
tWR............................................5
tRFC...........................................53
tRTP...........................................4
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................Auto
Channel A
Static tRead Value.........................:[11] Auto
tRD Phase0 Adjustment...................Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:[6]Auto
Twr2wr(Different Rank)...................:[6]Auto
Twr2rd(Different Rank)...................:[5]Auto
Trd2wr(Same/Diff Rank)..................:[8]Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
DDR Write Training...........................:Auto
Channel B
Static tRead Value.........................:Auto
tRD Phase0 Adjustment...................:Auto
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................:1.25
CPU Termination…..... 1.200V*.......:
CPU PLL…………………....1.500V*.......:
CPU Referen.…………....0.760V*.......:
MCH/ICH
MCH Core…………….....1.100V...........:
MCH Reference….…….0.760V...........:
MCH/DRAM Ref.…......0.900V...........:
ICH I/O……………….....1.500V............:
ICH Core…………...……1.100V............:
DRAM
DRAM Voltage ……....2.04V............: RAM Sticker says 2.0-2.1v
DRAM Termination .…0.900V............:
Channel A Reference 0.900V............:
Channel B Reference 0.900V............:
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
