GA-EP35 with power problems
PMildren
I bought a GA-EP35-DS3l motherboard several months ago and have had issues with it ever since. Here is the problem, it acts as if its not getting any electricity, if I just plug it strainght in from the PSU.
I have troubleshotthe PSU, its fine. I have troubleshot the power switch on the case, its fine. I have switched the motherboard out to another case and the same issue exists. Now, I have been able to get the motherboard to power up, if I plug it in cockeyed and once it begins to power up, I push the plug fully in and seated. But I have to either have it pushed left or right and only have the bottom few plugs mostly into the connector on the motherboard.
I am not sure if I can send it back to Gigabyte, I bought it second hand on here. The computer runs fine once I get it booted and will run stable for weeks on end. Once the system runs for a few days I can even shut it down over night and reboot in the morning, but ifI let it sit for more than a day, I have to do the plug dance again.
Any ideas or observations?
Secondary question, I dropped my monitor here recently and I think I broke something inside, the top is slightly darker than the bottom half. If I am going to replace one or the other, there can only be one atleast for 6 months or more until I can get some money saved up. Which would you replace first.
It seems that the decision was made for me last night. I went out partying with some friends and when I returned to my room, my monitor stopped working. The screen would come on for a second then it would go black. No OSD, no DVI signal, no nothing, just black. So I went out and bought a new monitor today.
I suggest you contact Gigabyte and see if they'll allow you to RMA it. Even if you bought it second-hand, some companies will still allow you to RMA items.
