Well if you click the Newegg link it seems quite a few people have bought and commented on the board... just cant seem to find any information on it's overclocking. And just because it's a small overclock doesn't mean it's possible. It's up to the BIOS and software, that of which is my concern.
Lastly my only other concern with this board would be the VGA. Most people on newegg are listing the VGA as a con in the review. I'm currently using a 24" 1920x1080 HP monitor with DVI from my current PC, and I like the sharp image. Is that going to change from a VGA outpout? I really don't want a blurry display.
Would a USB 2.0, or USB 3.0 to DVI adapter pretty much solve that issue? It looks like they make a few models for under $60 that do 1920x1080.
Any ION motherboard would have done the job too
Well as I said in an above post, all I need is 2Ghz to run 1080p and Im not interested in ION, I want a single chip solution, and ordered the Gigabyte board today. I'm going to overclock the Atom D525 from 1.8ghz to 2.0ghz![]()
You should take your own advice and read my post. I did not say it was a Core 2 CPU. I said it was Core 2 based, which it is (maybe you should look things up while you're at it as it sounds like you need to do your homework). I think you're mistaken in believing that that Atom chip will outperform an E1300 merely on the basis of having more cache and hyperthreading (and you can't compare FSB because the Atom CPU doesn't have one). If you really think clock speed is everything, why don't you try playing back 1080p content on a 2ghz Pentium 4 (I'll save you the trouble and let you know that a 9+ year old CPU won't cut it).Did you read any of the above posts...? It's not a Core2 chip, it's a crappy 2ghz celeron that can play 1080p, so yes raw clockspeed is everything when all you're trying to do is play 1080p youtube videos. A 2ghz Atom D525 is more powerful then an E1300 Celeron dualcore @ 2ghz. It has more L2 cache, two more virtual cores and a higher FSB.
I had an ion board with a atom 330... There is no way it would push 1080p decently.
Just because I chose not to change my handle after using it for 10 years doesn't mean you should dismiss me as not knowing anything. If anything, I may know a hell of a lot more. You may do this for a living, but so do I (previously a network administrator for a sizable company and more recently the director of the VoIP division for an ISP). You're the one that started all this anyway.Wow someone's feeling defensive. lol. Listen bud, I build computers every day for a living, and don't need some guy named "Blue Fox" talking down to me about what I do, and do not know. Thanks for trying to help but I don't need the attitude. I've also got the motherboard now, and have overclocked it and guess what! It plays 1080p. What a surprise...
It's not a Core2 chip, it's a crappy 2ghz celeron... A 2ghz Atom D525 is more powerful then an E1300 Celeron dualcore @ 2ghz. It has more L2 cache, two more virtual cores and a higher FSB.
Going by specs on sheet alone, the Atom D525 @ 2.0ghz should outperform the E1400. The E1500 has 512mb L2, 2.0ghz, two physical cores. The D525 has 1MB L2 cache, two physical cores, and two more virtual cores. Therefor it should run better. Not to mention runs cooler and uses WAY less wattage.![]()
End of story, end of argument, end of lecture. Good day!
that e1400 is an Allendale Chip & Allendale is same as Conroe except 1/2 the cache & lower FSB (800 vs 1066) So yes the architecture is the same, but the performance is not.
Gotta pay for that feature.So if you click on thread tools you can then click on close thread.. You have the board & your opinion & Zap and BlueFox have no board & there opinion's.. There is no point in anyone arguing about it anymore.
Gotta pay for that feature.![]()
Yeah I'm really wishing people would GTFOMakes me regret ever joining this forum if people are such ***hats to new members.
This thread is hilarious. I love how all the OP's comments were editted out but you can read them all in the quotes.
OP, you should google "In-order architecture" and "Out of order architecture". That concept alone will illuminate why atom is inferior to core 2. There are multiple other non-clockspeed related design features that also need to be factored in. Computer architecture is a very complex subject, it cannot solely be summed up by looking at clockspeed, cache, and hyperthreading.
