GA-965P-ds3 NO post ?
sandbagger
ok just tried building a C2D system and my first intel in a long time ( have built prob 100+ machines in the past)
using the gigabte DS3 board with a 6300C2D with muskin 6400 memory 2gig 7900GS video card and a seasonic S12-430 I know the power supply might be a bit low for a lot of you but this is for a HTPC and wont be overclocked only 1 HD and one DVD drive only.
I cannot get this thing to POST at all( and no beeps) tried one stick of memory at a time in all slots, no memory/ no beeps, no cpu/ no beeps, reseated the cpu no help there either. I did try another PSU and that didnt help either( its only a 380 seasonic in a older system) Yes I did have the 4pin connector on the board and the video card power pluged in also. I dont have access to any slow memory to try but did borrow a friends good ram that he had no problem booting with in a board and that didnt work either. I also removed the bios bat for a long time and reset the bios too. I have no idea what version is in it since it has never posted
Is this just another bad DS3? from newegg?
any help things I missed would be apreciated.... thanks
Did you try plugging another connector into the extra power connector on teh board? There should be one above where the CPU is.
Not on my DS3 there isn't. The only power connector above the CPU is the standard 4 pin. No molex or anything.
The DS3 has no built in speaker, did you try hooking one up? Sounds like a dead board to me though.
Yea had the 4pin power also hooked up and robed a speaker out of a old case and not a single beep EVER
new powersuply just powerd up the old board (754pin 3000+) so I can rule that out now too.
looks like any savings by going mail order just got nulled
The DS3 is picky with memory. I had the same problem with Mushkin ram.
The Mushkin ram went back and I put in some generic Micron DDR2-667 CL5 with D9GMH chips and not only did it boot up but it ran like crazy.
It was rock solid stable up to DDR2-944 speeds with CL4 timings at 2.1 volts.
Gigabyte lists on their website compatible memory. You likely won't find your memory on their list.
The Mushkin ram went back and I put in some generic Micron DDR2-667 CL5 with D9GMH chips and not only did it boot up but it ran like crazy. It was rock solid stable at DDR2-944 with CL4 timings at 2.1 volts.
Yea I understand the whole problem with picky memory and the possibility to use slow ram to boot with and then bump the voltage in the bios but I guess my question is shouldnt this thing beep at me and give me the finger at least ? did yours beep with the mushkin?
It didn't post so there was no beep. It just sat there with a black screen and did nothing.
The CPU fan was spinning but beyond that there wasn't much else happening.
Ok but without any memory in it at all it should beep right? every board that I have ever had will beep if no memory is present or video or cpu for that matter
Can someone pull there memory and see if they get beeps ? I just want to make sure its not the memory before I send it back and spend MORE money.....
Thanks
Thanks
Mine didn't beep when there was no memory installed on the board. I sometimes have the same problem, where the computer powers on, but all I get is a black screen and the power button on my monitor flashing. I am still in the process of figuring out what is wrong with my mobo too though.
just as a follow up
newegg replaced the board and I got it thursday night..... the new one booted on the first try so it was just a bad board
It couldnt have been a memory problem since the same ram worked in the new board.:mad:
Not sure what the old one was but I think it was ver2 no idea what bios it had.
The new board was a ver2 with bios 9 I think.... at work right now. wasnt too concerned since this is a HTPC machine for HD-DVD playback and wont be OC it.
Replacemnt board did come out of the east coast though
just saw a post about rev 1/2 the easy way to tell is the heatsink design.... well if thats true then the first board I had was rev1 and the replacement is rev2
now that you got it working our not even 1 bit tempted to oc it at all???? wow talking about resisting temptation!
No actually I have thought about underclocking it.... to get it to run a bit cooler but what I really need to do is get a quieter HD
I dont need a ton of CPu for HD-DVD playback but I needed more than my onld amd3000+754pin chip and agp card would do
got to love HD-DVD at 1080P on a 110"screen ( yes my projector outputs 1080P!)
