Hi, I have had this board for several days now and I simply cannot get through an installation of XP. I get to the "Setup is copying files..." point, about halfway through and get cannot load the following file... spnike.dll etc. messages. It happens with every other file, it gives the option to hit enter to try again and, if I hit enter several times, it eventually loads the file only to hit a snag again several files later. It eventually gets to the point where it simply will not load anymore files. I have tried every thing I know to try... The board, the memory, the hard drive, etc are all brand new.
Could this be a memory issue? That is the only thing I can think of and I have no other DDR2 memory sticks to swap out in order to check. Thanks for your time.
