GA-8INXP 2.4A @ 2.8 higher = errors?!
afropuff
Hello all,
I was wanting to get some advice on my overclocking problem. I have a Gigabyte GA-8INXP mobo w/a 2.4B. I can set the FSB to 155 and run prime95 all day w/out errors. If I go higher, to around 157, prime95 locks up after about an hour. My temps are fine. I was wondering what you would suggest? All settings on my mobo are default except of course the FSB and the AGP/PCI lock. All memory, cpu ect.. voltage is all set at default. Should I raise those, and to what values?
Anyone got any suggestions??
thnx
-fro
EDIT---- 2.4B not 2.4A
