GA-7N400 Pro2 code 12
I just assembled this system:
Motherboard - Gigabyte GA-7N400 Pro2 Rev 2.0
Processor - 2.2GHz AMD Athlon XP 3200+ 400MHz 512K Socket-A
Ram - A-Data 1024x2 for 2048 Meg of Dual Channel DDR 3200
Hard drive - 1 Maxtor 80GB Ultra ATA-133, 7200 rpm Hard
Video - Hercules Prophet 4000XT 64Meg AGP 4x
Audio - Intagrated Realtek AC97 6-Channel Audio
Optical Drive - A-Open 16x8x16 DVD-RW
NIC - Intagrated Realtek 8110S 10/100/1000 LAN
USB - 6 Intragrated USB 2 ports onboard
FireWire - 2 Intragrated IEEE1394 FireWire ports
Powersupply - Retail+ 475 watt
OS - Windows XP Pro sp2
After installing XP I end up with two entries in device manager with yellow ! next to them.
Nvidia nForce2 AGP Host to PCI bridge ! and PCI standard PCI to PCI Bridge !
Both have code 12 cannot find enough free resources, and advice to disable other devices to free up resources. I have both serial ports, the parallel port, sata, sata raid and the IDE raid channels disabled in BIOS. So far I have done 3 clean installs. First I installed XP then sp2 then the drivers from the CD that came with the motherboard. I ended up with the above problem plus no network and couldn't install my video drivers. On the second install I used the latest drivers downloaded from the Gigabyte sit, same out come as the first go around. On the third try I installed my drivers before installing sp2. Network drivers installed this time but still had the two entries in device manager. Network wouldn't work after installing sp2. The network card disappeared from device manager. Reinstalling it got it back but with a cannot start error. I have cleared the CMOS and gone over all the BIOS settings several times. The processor is detected properly and running at the correct speed, temp is OK too. The 2 gigs of ram is detected and the BIOS reported that it was running in Dual channel mode. Checked the BIOS, already have the latest version. Installed win 2k pro and PCI to PCI bridge was code 12 right away. It only goes down hill from there so i didn't go any farther with that instal. I took my Hercules Video card out and put an old trident PCI video card in. The code 12 disappeared and I got a new hardware detected. Started a fresh XP install and was able to get everything working, sound network etc. After all was said and done though I ended up with a code 12 for the trident video card. I was hoping it was just my Hercules card that was not compatible, it's only AGP X4 and has a Kyro chip-set. The motherboard supports AGPX4 and X8. Even with the errors both video cards work and I can go to high resolution on the screen. Now I'm not so sure and I am thinking maybe the motherboard has a fault. I was planing to replace the Hercules card with an AGP X8 Nvidia card but I can't do that until next Christmas. Now I'm not sure what to do next. Google isn't helping ether. Has anybody got any suggestions or insight on how to try and sort out this problem? :(
I am sure that you have checked the BIOS to see if devices are manually configured to a specific IRQ?......right? And if they are, you set them to auto, right?
