G80 SLi problem...
AYO VIN
Hey wassup fellas, I have a problem now after reformatting my computer. I cant seem to enable SLi anymore? The options isnt even there.
Tried reinstalling nForce drivers and video drivers...still no go.
Left one card in to see if it works and switched to the other, Both are working fine?
Need some help here!
i had the same problem, just follow these steps and you will get the option back.
download 97.44 drivers
download driver cleaner pro
boot to safe mode, control panel, add remove programs, remove nvidia drivers
run driver cleaner to remove nvidia drivers
reboot
install 97.44 drivers
reboot
wipe the smile off your face!!!
Frank
Hmm well I kinda did that. I reformatted twice now. So the system was clean with no drivers and still after the reformats I still cant get SLi?
Two questions.
1.) did you update/reset your bios anywhere in there?
2.) Have you swapped the SLI connector around?
First of all, remove one of the cards so you just run single card.
Remove drivers with Driver Cleaner pro and uninstall the video card in system devices in controllpanel (or right-click My Computer and choose properties)
Reboot and reinstall drivers.
Run a game and some benchmark to see if all is working.
Turn off computer and install the second video card.
Check BIOS settings so SLi is enabled.
Boot up and enable SLi in windows, should be in the drivers.
Hope that will work.
Nice OC on the 6600 there! Naw sorry, I don't have anything useful to add.
What motherboard do you have? Sometimes the sli settings in the bios aren't all that obvious.
umm...evga 680i :rolleyes: his system spec is in his sig ;)
