G7 mouse, which wireless keyboards are compatible?
shebalord
Hi ppl,
I currently have a Logitech G7 wireless mouse. I'm now using a generic PS/2 keyboard and now looking for a wireless keyboard that will be compatible with the existing receiver. I'm leaning towards a Logitech keyboard, but if something else are compatible, please let me know!
The bottom line is I want to use my G7 receiver for the keyboard as well because my G7 receiver also recharges my battery. Better yet, if I can find a keyboard that uses the same battery as my G7 mouse that would be AWESOME!
Thanks in advance!
Where did you see that the G7 receiver works with keyboards? I know my G7 worked with my... MX Duo receiver, and whatever keyboard came with the MX 1000, but I didn't know that the G7 receiver worked with keyboards...
As far as I know, the G7 receiver doesn't work with any wireless keyboards. I have separate receivers for both my G7 and S510 keyboard.
thanx for the replies guys!
i think i'm confusing you guys....i dont know if my G7 receiver works with any keyboards out there...the reason for this post was to find out if there are any out there that will be compatible!
but from the replies i guess im out of luck on finding one?? if so, can you guys recommend a good standalone wireless keyboard?
thanx again...
